I’m running 27.5 x 2.4 Geax Goma. Tubeless at 20psi, No studs. I just put a fresh set on a couple of weeks before Christmas so I have good tread
You have to be aware of ice but for the most part I ride exactly the same set up in the winter as I do the summer except I usually run 24-25 psi when the trails are dry
Shiny ice = bad
Bumpy ice = sorta grippy = good
That’ll be fine in most situations, but when Wrandees gets totally tramped down and turns into a bobsled track after a rain/freeze cycle, you’re not going to have any fun at all.
They’re a ridiculous expense for the number of times you need them, but when you need them, you’ll regret not having them!
Agreed. You’ll only need studs a handful of times, but being able to ride an icy flow or across a frozen lake is some of the best riding out there. Well worth the cost IMO.
I rode at Second Lake last night. If I didn’t have studs, I would have been a lot slower. Maybe I would have been okay without them, but I felt a lot more confident with them. The trails there are in great shape.
Does anyone know if you can ride anywhere? I suspect Spider, Fight and Whopper are no where near trampled enough (or at all) but I would settle for Shubie if it was somewhat plowed/beaten down
Sometimes I just like to pedal. The snow makes it all the more fun/hard/fun
Snowshoed Wrandees from Cowie Hill Road down to the other end. At the dogwalkers parking lot there was a very small section that would be ridable (for a non fatbike)–maybe a 1/2 - 1 km section down along the lake. Stream climb is still messy and wet although for some reason it still had the most walking snowshoeing traffic. Beautiful out there though.
It isn’t ripping Wrandees, whipping Whopper or even fighting Fight Trail but Shubie Park is spectacular right now. I’ll definitely hit it up again tonight before it gets all covered over again tomorrow
Update: went back out to wrandees this morning (sat) and conditions are much better. Lots of traffic has packed things down very well and frozen a lot of spots. You could easily ride almost to the big bridge without issue and a fat bike could probably go almost to Cowie Hill Rd. Snow and rain is falling though so by time you read this conditions will most likely have changed…
I’ll keep an eye out for you, @brightwhite. I’m taking my wife, daughter and dog in for a short stomp too. Later, I’ll get a bigger stomp in for myself, though.
