I spec mount
Went otb, snapped the I spec mount on my xt shifter, anyone have an i Spec mount?
There are three versions of I-Spec (A,B,II). Limited to no cross compatibility sadly. There’s a chart online somewhere that outlines the difference.
Im sorry, I spec B. No hook.
Which part do you need? The actual part attached to the shifter that has the hole through it? Or some of the hardware?
the actual part attached to the shifter to the break mount. She snapped shifter is still good, don’t see the point in buying a new one if I can avoid it.
