Specialized Command IIRC dropper post. 125mm/31.6 $100
125mm drop
31.6mm diameter
Internally routed
Adjustable air pressure return ( low pressure, 25psi)
Used two seasons. Serviced once, works great.
Includes post, remote, and cable end. You’d need a shift cable and some housing for the install.
$100 Located in Kentville
Josh, can this be swapped to external cable?
No, unfortunately @Coaster2
IR only. So you would need to drill a hole in the seat tube to make it work. :metal:
I’ll get it. Any chance you’ll be heading Halifax? Pmed you too.
Bump for this again.
No one has put any money in my hands for this, so first come first serve.
Make an offer before I put it back on my hardtail.
