Looking at a couple hours to spend at a spot in Wolfville this weekend - if I can only hit one, should it be Reservoir or Anima Mundi?
Both systems are relatively short.
Anima mundi has many more twists and turns. The trail itself is mostly flat.
Reservoir has a few more challenging tech sections, plus a skills park with man made features and a small pump section. If you want to incorporate the climb from wolfville, it adds some distance and a nice climb.
Both will entertain you for a couple of hours for sure.
Awesome - thanks for the overviews!
