I looked at the tubes, both were snake bites, different distances from the valve. I think it was a mix of riding on too low a pressure for that terrain and maybe a bit of bad luck. Will check air pressure before riding this evening. Learning as I go!
Haven’t been impressed with my Knobby Nic, in a month of riding, I’ve had a few punctures, last ride with them this week the sealant was failing to seal the puncture, as it kept opening up again as I rode, even trying my best to baby it.
Put a tire patch on the inside of the tire and a tube in it for now, not sure if I will give it a try again tubeless or not… McIntosh seems to wear hard on tires anyways if you are riding there a lot, may just ride it till its worn down this fall/winter and set the replacement up tubeless… Likely a Maxxis. The Maxxis I put on the rear hasn’t punctured at all, in the same riding and mileage that has seen the front Schwalbe tire puncture several times.
The Nobby nic is a light duty trail tire in my opinion. They make good tires but I would recommend the Hans damp or magic marry instead. I only run Michelin now so you could also go that route haha.
Wow. On my 26’er if I was running 25 psi, I’d be pinch flatting all day. But I’m heavy. 235 lbs + gear. 35 psi more like it for me. Usually 40 for safety. On my current 27+ (3.0 inch tires), 15 psi.
