First real dive into cold weather with my new fork last night and it stiffened right up.
Anyone else experience this?
I suspect it is using a heavier fork oil than my old one. Any thoughts on how to remedy this?
It is a Manitou Mattoc.
Design and patent yourself a pedal powered fork/shock heater gadget
I know you got the knowhow. Probably haven’t done much of that kinda stuff in a while, might be a good project.
Lol, it would be nice if you could change the oil without major disassembly, though.
What are the conditions like in Pictou these days, @Chiz?
Are you sure it’s the cold? Was it stiff before or after the ride at room temp?
It was good at the start of the ride. I can check tonight if it is back to normal after being in cozy basement though.
Sloppy around here but this next couple days should freeze things up enough to have a good frost layer there anyway. Haven’t been up the mountain at all since the last time you guys were down.
A nice crust will make it good even around Benson’s Cliff.
I’ve had front forks and shocks stiffen up a bit in bitterly cold weather. A lighter oil would help for sure, or just buy a fat bike LOL. I’ve resorted to just using a rigid fork in the winter overall, even on my old kona.
I was out for a ride last night and noticed that my fork was harsher than usual on roots and stuff like that. I’m due for maintenance on mine so I’ll be considering a lighter oil. (I’m running 5 and 15 wt in it currently.)
