SOLD- heading out to BC!
Use it for trail riding or lower it with travel spacers for a DJ machine- easy to set it to any travel between 160mm and 100mm or even lower. Rebound, high and low speed compression controls. Stanchions are in excellent shape. Straight 1 1/8" steer tube at 7 5/8". For 26" wheel. $450.
Located in HRM. If you’re going the DJ route, I have travel spacers that can go with the fork or I can install them for you.
