I’m selling my mechanic owned 2018 Specialized Stumpjumper Expert 6Fattie size large. I purchased it new in the summer of 2018. It’s capable of running 27.5" plus or 29" wheels with 135mm of rear travel.
The shock is a Rockshox Monarch RT3 that was recently rebuilt by S4 Suspension, and has not been ridden since the rebuild. All of the suspension pivots were recently serviced. (01-Oct-19). All cables and housing, and the chain were recently replaced. The tires are new and have one test ride on them. The sealent and valves were replaced with the tire change. The bike has been given a complete overhaul and is in very good condition.
The frame is in very good condition, with typical cosmetic scratches. There is no structural damage to the frame. It’s got the SWAT door and the original SWAT toolbags are included.
The FACT 9m carbon fiber Trail Chassis with Stumpjumper FSR M5 alloy rear end blends stiffness with light weight to form the pinnacle of efficiency, while fully enclosed cable routing and an integrated SWAT™ Door create exceptional handling and zero-hassle storage.
Included are the following:
Frame: Stumpjumper frame w/rear maxle, bottle cage, and seatpost collar. FACT 9m carbon front chassis w/ Specialized M5 Aluminum rear end, 29/6Fattie Trail Geometry, SWAT™ Door integration, PF30 BB, fully enclosed internal cable routing, ManFu link, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm of travel
Rear Shock: RockShox Monarch RT3, Rx Trail Tune, AUTOSAG, rebound and 3-position compression adjust, 197x48mm. (Serviced by S4 Suspension 10/19)
Fork: FOX 34 Performance 29/6Fattie, 51mm offset, 15x110mm thru-axle, 150mm of travel. Heritage decals.
Brakes: Shimano Deore XT M8000 (bled 10/19)
Rotors: Shimano ICE Tech Front 203mm/Rear 180mm
Brake Adaptors: North Shore Billet
Drivetrain: SRAM GX Eagle 12 speed, 10-50 cassette. XO1 Eagle chain (new 10/19)
Headset: FSA integrated headset. (Serviced 10/19)
Bar and Stem: Specialized Trail 780mm/Specialized Trail 60mm
Grips: Specialized Body Geometry contour lock-on
Bottom Bracket: PF30 bottom bracket (serviced 10/19)
Crankset: Truvativ Descendant 170mm crankset, boost spacing, 30mm spindle, 30t direct mount chainring.
Pedals: Shimano SPD 424 (Serviced 10/19)
Dropper Seatpost: Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, 125mm of travel.
Saddle: WTB Volt Pro
Wheels: Specialized Roval Traverse Carbon 27.5, hookless carbon, 38mm inner width, 24/28h. Specialized boost sealed cartridge bearing hubs, configured tubeless with muc-off valves and muc-off sealent (10/19)
Tires: Schwalbe Rocket Ron EVO LS. 27.5 x 2.8 rear, 27.5 x 3.0 front.
Asking $3400 OBO.
