OMG - For those of you who used to be on the old site. There was no gallery for the first several years, and we would do the updates manually after every race weekend or event. Not that any of this means anything but this is what we used to have to do just to build a gallery page. LMAO.
HTML updates for ecmtb.com
Content Page Text.
Open Dreamweaver
Hit F5 to open the site window.
Navigate to the section which you will be updating.
Open a page that is similar to the one that you are planning to create.
SAVE AS immediatley. Make certain that you save it to the same folder as the other docs. There can be NO SPACES in the name. Use lower case.
Select the header text to the right of the section name at the top of the page and change it to the new title.
Open your Word doc with your final, edited text.
Select all of your text in Word and COPY it.
Select all of the body copy in Dreamweaver. Choose PASTE AS TEXT from the edit menu.
You will now need to go through and add hard RETURNS at the paragraph breaks. Find where they are in the text, insert the cursor and hit return. If it drops down 2 lines, you will need to pull it back up. You shouldn’t be able to insert your cursor in the white space between two paragraphs.
Open the SOURCE window by hitting F10.
Find your body copy. See at the beginning of each paragraph where there is a
or just a
tag? Body text has to have
in there. Items that are subheads need to have
instead. The author’s name uses
and the header at the top of the page is
Preview your page in the browser by hitting F12. Make sure everything looks right, especially the text formatiing.
If you have bulleted lists, seperate the items with a hard return (same as 7) and then select them all. Click the bullet button in the toolbar. These items do not need to have a class applied to them, because I control this with a
- class in the style sheet.
Save your File. (You’ve been doing this all along, no?
Inserting images
Drop your properly named and sized images into the current directory’s IMAGES folder. Make sure that everything is uniquely named.
Go back to your Dreamweaver document. Insert hard RETURNS between paragraphs where you want to place an image. Only three to four images per page please, especially if they are portrait.
Put your cursor in the open space and hit CONTROL-ALT-I. This should bring up the images selction dialog.
Find your picture in the IMAGES directory and select it. Hit OK.
Repeat steps 2-4 for each and every image you want to place, er, palce.
Select the first image on the page. Go to the SOURCE window by hitting F10. Your image HTML should still be selected and will be enclosed in a
tag (most likely). You have to remove the class info so that all that is left is
. This is for Netscape’s benefit which does not handle class’ and images well and tends to overlap the bastards.
Save your file.
Editing the SSI Navigation Document.
In order to make the page accessible from the left bar navigation, you need to add a line to the text document SECTIONnav.txt.
NOTE: NEVER EVER EVER open this file in Dreamweaver. Weird shit happens. Instead, open it in a straightup text editor.
There will be a collection of lines that look like this:
Select one and copy and paste it to the top of the section you are editing.
Change the name of the link in the a href tag. Make certain that you spell the name of your file exactly as it is, no spaces and with the same case as your file name.
Change the title (in this case the “Jacks Lake XC”). Make it exactly the same as the title from the page, for consistency.
Save this file. You can’t preview this locally.
Creating a Teaser
Open the default.shtml page for your section.
Change the headings, text and images to show the section’s new contents. Make sure you use the same styles as are used elsewhere in the site.
Update the links too.
Uploading
Upload all of your files (images and HTML docs). DO NOT UPLOAD the nav.txt file or default.shtml. To upload, select the files, and click the Put button.
Send out an email with the path to your document so that it can be checked by the rest of us.
When it is signed off, upload the other two files and let Jeff know to add a note on the front page.
Crack a beer and move on to the next file.
