Big Honzo was designed around a 27.5+ wheel but is cross compatible with a 29” wheel, allowing you to create your favorite configuration to get the most out of the terrain you ride the most. The Big Honzo features 130mm of Rockshox front suspension, boost spacing, a SRAM NX 1x11 speed drive train, a dropper post and hydraulic disc brakes in an affordable package.
- Frame Material: Kona 6061 Aluminum Butted
- Wheels: WTB ST i35 27.5”
- Front Suspension: 130mm
- Fork: RockShox Recon RL Solo Air 130mm
- Crankset: SRAM NX
- Drivetrain: SRAM NX 11spd
- Brakes: Shimano hydraulic with 180mm front / 160mm rear rotor
- Seat Post: TransX dropper post
- Cockpit: Kona XC/BC 35 Bar/Kona XC/BC 35 Stem with Kona Key Grip Slip on
- Front Tire: WTB Ranger TCS 27.5x2.8
- Rear tire: WTB Ranger TCS 27.5x2.8
- Saddle: WTB Volt Sport SE
$1,899
