Less is More?
Seems this week will have most of us thinking more about our bikes than riding them. I’ve been thinking about how many of my 11 gears I use for most of my riding. I would say I rarely use any gear higher than my 5th lowest here in the HRM. My lowest is a 46 tooth cog. I can’t imagine using anything lower. I was intrigued by Sram’s E bike EX1 cassette but was shocked at the price. It would be nice to have less gears. More on the low end. Maybe replace the limit screw with a longer one in my derailleur?
How many gears do you think you use? Do we need 12 cogs? I suppose I could get a 28 ring and slap on a 10 or 9 speed cassette with some sort of spacer. What do you think?
Too high a degree of variability to get consistent answers. Would depend on your riding style, where you ride, what you ride, etc.
Forgot to contribute. I ride a “Downduro” bike that is a 9 speed (11-42T) with a 32t front oval ring and 26" wheels. I 100% plan to go to 11 speed, 11-51T over winter to help with the tiny wheels and climbs.
I’m always in awe when I see bikes with no front derailleurs and cassettes bigger than my disc brake rotor.
My last mtb came with only two chainrings up front, what’s up with that?
Have to say, I like the one chainring. I ride a 27.5 Knolly with a CCDB In-line Coil. I ride mostly here in HRM, both Whopper and all the MacRun/ Flat Lake trails. I don’t think I use a very high gearing at Keppoch.
I used to ride a single speed exclusively, and still bring it out from time to time, it can be a magical experience. Type 2 fun for sure.
there was an article on NSMB.com awhile back that had some interesting thoughts on the subject fo fewer gears
https://nsmb.com/articles/does-future-have-fewer-gears/
Respect to anyone grinding out 4-7 hour 1000m + rides without a dinner plate around here.
Riding at the Railyard, I would say I use all my gears every single ride. I could get away with 1x 9,10,11,12 but more importantly i need a 11-40 range at a minimum, prefer to run 11-46 with a 34 tooth front ring for more speed on the low end and easy climbing on the other.
The 1x12 500%+ dinner plates give a lot of versatility in gear range and reasonably tight spacing, which I would not do without:
  • commute to work, then trail ride on the way home
  • epics where you link slow singletrack with fast gravel or road, perhaps in a paceline
  • riding in other locations where giant climbs are combined with fast trails
etc…
I don’t see much downside to this versatility, other than initial cassette cost. Dinner plate drivetrains work great, and in my experience with XO1 the chain and cassette life is much better than my old drivetrains (and I date back to the era of 3x5 drivetrains!)
If all my riding were slow tech, or winch-and-plunge (much of the Vancouver North Shore), then I can see using only half of the cassette. But even there I’ve appreciated the versatility of road gears.
The longevity piece is HUGE. I’ve never had drivetrains last longer than with modern 1x systems.
NSMB has had some interesting articles over the last little while about building the perfect 7 or 8 speed cassette and then using various trickery to change shifter gates and such. Sounds like a pain in the ass to me, I’d rather be riding my bike than making it completely unrepairable with off the shelf parts.
When I was riding a 3x9 setup, I would replace my front big ring with a rock guard. No need for my top gears on technical trails. I would end up even more behind than usual on Shubie rides though. On my 1x11 bike, I never use the top gears on trail. They’re nice to have every once in a while on crusher dust or pavement tho.
I love some of those NSMB articles. Lots of goofing around with parts on the same bike frames. Their reviews seem honest and on the mark. It has been a go to site for me.
That is reassuring, for sure. I don’t see any new bikes in my future but if I did get one I would be counting on the manufacturer to spec the proper gearing for intended use of the bike. I’m not into reading tonnes of tech shite and mixing and matching. I just want something that works, by now hopefully most manufacturers have figured out 1 x Y.
Bikes have come along long way with specing complete builds to accommodate the intended desire.
My first “real” mtb’s rear derailer never worked and I was too broke to fix it, but the front three speed one worked fine. I liked riding it - instead of a bunch of gears to mess with, there was one gear for climbs/tech, one gear for trail, and one gear for road/downhill.
I still have a couple of 3x bikes in the stable and often find myself riding them the same way- as a 3x1 setup. Surprisingly effective.
