Is there any local shops that readily carry bolts for crank arms? Found out that one of mine was seized with a round head, and ended up having to extract it. Any help is appreciated.
I’m not sure what shop would have one of those in stock, but it would be a metric bolt and the length is measured from under the head to the end of the bolt. That looks like a M5x20mm screw. If you can’t find the screw from a bike shop, Fastenal or Transworld should have what you need.
Canadian Tire has a decent selection of fine thread/metric/hex head socket screws. Usually in the hardware section in pullout drawers.
If it’s a Shimano non drive side bolt chances are you are going to have to order one through a shop or online. Or grind your own down to fit. I remember having to order these before for people. I just had one round off the other day and rather than grab a random 5mm hex bolt I grabbed one off another dead crank.
Tldr, I think the Shimano crank bolts are narrower than regular store bought bolts
It is a shimano non drive side, hopefully ordering in wont be the case
Transworld under the Mackay bridge off windmill.
I have an extra, just checked it on my road bike to make sure it fits Shimano non-drive side (FC-M590 crank).
I just grabbed a similar length 5mm bolt and it went in no problem.
Either cdn tire, bike shop, or that place PM mentioned.
Specifications subject to change without notice.
