Long shot, but we had a mechanical issue on the trail last night. Seems a BB bearing seized and started backing out while pedaling, which resulted in a crank-arm getting worked off. Trailside repeairs were unsuccessful, and the second time the crank came off we lost a crank-arm spacer somewhere on the trail. Due to work committments, we’re unable to get up to look for it today, but if anyone sees this and happens to be rolling along Divide, could you have an eye for a small black metal crank spacer? (Yeah, I know. It’s a long-shot, hence the title of the post. Doesn’t hurt to ask?)
(Piece is in step 3 of this diagram)
Rough area of where final disconnect occurred, and crank-arm was put into a backpack. It’s likely at the left hand of this image.
