I am thinking about going to a mullet setup, looking to see if someone has a 27.5" front wheel that’s a 20x110 axle and I would imagine a tire no wider than 2.4". I want to see if the stories are true, and I can actually run such a wheel on my 36 float (26"). Hopefully someone in the HRM has one, I can just run out with my fork, check fitment, and that’d be the end of it.
I’ve got one but I’m not in zee city.
Where ya to?
Gaspereau.
Bit of a trip! Won’t be up that way until the fall, but if anything comes up sooner I’ll surely reach out. Thanks!
no worries.
FYI you could still test fit with a 15mm wheel if that’s easier for you to find.
I suppose the level of ease would depend on what people have available, good to know!
I can confirm this works. Had a buddy run this for a season. 27.5” with 2.4” in a 26” 36.
I don’t have that size axle but I’m running a 27.5"x 2.35" on a 26" Manitou Nixon fork, it fits but just barely, and it’s good to note that I’m running higher psi in my tire than I otherwise would so that the tire doesn’t rub on bigger jumps/drops
