A friend has an older downhill bike - Iron Horse SGS - that he wants lower gearing for trail riding (I know - not ideal for trail around here, but he likes it and wants to keep it).
He’s planning to change the crankset to a triple chainring setup, and put on a front derailleur, and I offered to help out. Having had a close look at the bike, I’m not 100% sure we can get a front derailleur on it.
I got thinking that a lot of you are going the other way - from triple chainrings at the front to single ring up front.
What’s the best/most inexpensive way for him to go to get better gearing for climbing?
Could he get a wide range nine-speed cassette, smaller chainring and keep his shifter and rear derailleur?
Triples will be much harder to find than a double chainring–except on super low end bikes. Besides, no point in a large chainring if what he’s looking for is low gearing. Get a double 24/36 front with an 11-36 rear stack and you’ll have all the range you need. Should be pretty cheap to do.
Lots of pics of the SGS online with a 3x setup, looks like there’s a stub for the front derailleur. There are lots of options out there both new and used for cranks. CRC has Shimano triple ring cranks starting at $38.99 for an Acera and going up from there- Alivio, Deore, SLX, XT.
But, since you mentioned the most inexpensive- put a 30T on the front and a wider range cassette in the back (Sunrace offer an inexpensive 11-40 9 speed cassette). A longer cage rear derailleur might be necessary. Is the current setup 8 speed or 9?
I THINK his current setup is 9-speed. There is a stub, which looks like you could mount a derailleur on, but it does have a post sticking out for mounting the chainguard, and there is no cable stop for the front derailleur cable. Not sure if that matters.
He did get a triple crankset, but the crank fits 68-73mm hubs, whereas his is 100mm, so he’ll have to see if he can return it.
Oh, a triple for a 100mm BB is going to be really tough to find. I’d go smallish single ring in the front and a nice wide range 9 speed cassette in the back. Definitely a compromise for trail riding but better than running a small range DH cassette.
