Newbi question about tires
Probably something that has been covered before, so I apologize if this is one of those annoying topics. I saw a post from 2019 but that was not yesterday. What are people running for tires?
I mainly go to Mac and Whopper with a bit of Gore. Right now I’m running Bontrager XR5 2.5" in the front and Maxxis Dissector 2.4 in the rear. I get a half season out of the Dissector, wish I could get more but the tire feels planted for my novice skill level. I am thinking about doing an assegai up front when it comes time to change out the Bontrager. Anyone else going with different versions front and rear? Is there a typical tire used around here? Is this too aggressive and I just need to get better on a less aggressive tire?
I’ve been riding maxxis minions for the past few years and find them to be a great balance between grip and fast rolling. But before that I tried a bunch of different options. And, honestly I think it’s just what works for you. I’ve tried everything from semi-slick to enduro casing and various widths. There isn’t a perfect option, so just try to find what you like
This is what chat GPT says
I think the most common ones people seem to use are an aggressor or DHR2 on the rear and DHF or Assegai on the front. I’ve tried a few different setups including the dissector which didn’t last long on the granite. Well less then norm. Right now I’m trying out DHR2 front and rear in the maxxterra compound and been liking it so far
If your riding gore,macrun and whopper
Try a Maxxis Rekon rear and forekaster front.
Assegai is insane overkill for those trails imo, and alot of unneeded weight.
My 2 cents
CN
I ride DHRii and Assegai, but that’s because I spend a lot of time at Bowater and similar. I find the Rekon is an awesome all around tire, a lot of grip but fast rolling
Anyone running the Continentals? They look like a good option.
I just mounted up a 2.6 argototal front and a 2.4 krytotal R in the back and have had no complaints. I am going off of a maxxis 2.5 assegai front and 2.4 dhr 2 rear setup. I mainly ride McRun, but run the same tire setup no matter where I ride. I always go for bigger and beefier enduro style tires as the extra grip comes in handy for saving my bacon when I make terrible line choices.
I have the Krypotal F and R in 2.4 in stock at Granite Suspension. Shoot me a PM if you are interested in pricing, I also have a handful of Maxxis rubber in stock as well.
I run assegai and dhr on my ebike which is an enduro setup. Primarly ride it at wentworth where thats primarily dirt works amazing.
Ive had it in mac run twice found it to be too grippy ..
My trail bike is currently setup with dhf and dhr which is good all around which has seen countless trips to mac run , wentworth keppoch and railyard plus some other spots..
I found dhf and dissector the best for mac run, dhf dhr best for dirt. My back tire is currently a dhr that will need replacing by mid summer and im putting a dissector back on
My bike came stock with the same bontragers you have up front. The rubber compound in them is quite soft and wears quickly especially on the granite
The back tire was worn out within 700 kms i believe the front wad good for about 1500.
