Ibis Ripley V4 XL frame with Fox Factory DPS shock 175mm Fox Factory Transfer dropper
Bike has a few chips in the paint as seen in the photos but is otherwise in very good condition.
Includes headset but not the bottom bracket seen in the photos.
Rock flap came off today while disassembling and washing. Have new one on order and will include with frame.
Also one bottle of Ibis touch up paint will be included.
According to Strava I have just under 500km’s on the frame.
Rear shock was just serviced.
I am including the Fox Transfer post as it will not fit my new frame. It has a couple marks on the Kashima coating you can see in the pics.
The dropper works fine but it is likely due for a service.
** COMPLETE BUILD AVAILABLE**
Complete build specs, Parts are brand new unless otherwise stated
- SRAM GX Eagle, 12spd
- SRAM GX Eagle 148 DUB 34t
- SRAM XG1275 Eagle, 12spd, 10-50t
- SRAM DUB 68/73mm Threaded BB
- SRAM Level TL
- Avid Centerline 180mm
- ESI Chunky Grips
- DT Swiss 370, 15x110, 6 bolt, 28h
- DT Swiss 370, 12x148, XD, 28h
- RaceFace AR Offset 27 29"
- Sapim Race
- Maxxis Rekon Race, 29"x2.4WT, 3C, EXO
- WTB Silverado Medium Cromoly SL Fusion Saddle or WTB Volt
Raceface Next Carbon bar 760mm - Not new
Raceface Turbine Stem 35mm - Not New
Fox 34 Grip2 damper 130mm - Not New
Fox Transfer Dropper post and headset from original ad also not new
Complete Build $6000
