I have some tools now from the good folks of mrwa and would like to put them to use this Thursday night we are currently allowed to gather in groups of ten but most practice social distance procedures. meet at the cul de sac 6.30pm and we will have a very short hike in from there. this is an unofficial event trial to see if we can do this with out any issues.
When: Thursday, 11 Jun 2020, 6:30pm. Where: Alabaster Way Cul-de-sac
MRWA Trail Maintenance Policy and Procedures
Covid-19 Edition 2.0
31 May 2020
The McIntosh Run Watershed Association (MRWA) wishes to provide a safe work environment for all MRWA staff and volunteers and help contain the spread of COVID-19.
In order to continue work and maintenance on the McIntosh Run Trails, work may proceed as long as the work can be done while adhering to the Covid-19 Declaration of Emergency and current Health Protection Act Order (HPAO). Trail building and maintenance will only be done as follows:
Work groups will be no larger than permitted by current HPAO.
All workers must be experienced MRWA trail building volunteers or trail crew members.
Workers from different households/bubbles must maintain at least the separation distance required by the current HPAO.
Workers from different households/bubbles must not share unsanitized tools. Tool handles must be cleaned with 60 – 95% alcohol before sharing outside your bubble. Best practice is to not share tools at all.
Workers must wear a non-medical mask when a task requires working closer than the separation distance in #4. Maintaining the required physical distance as much as possible is best practice. Follow mask advice from the Government of Canada.
The work zone on an open trail must be signed at each end instructing trail users to walk through and give the workers 2 metres clearance.
Thanks guys. This spot definitely needs attention.
All the trails are getting a lot of wear - which is good, I guess!
In the past couple of days, we (the MRWA crew and I) also worked over I/O, and the rock work at the bottom of the ramp+2bridge spot on the Attic. Check it out.
I think most people ride it from cul-de-sac to the Attic, which I like for the flow into Schnitzel (spelling?) and then continuing on the Attic to other trails. By “backwards” I think he means from Attic to cul-de-sac.
What…up over that rock roll-down…but why…why work against gravity? It’s soo much smoother to ride it counter-clock wise from the cul-de sac to the Attic
