Great beginner trail bike. Would be fine on anything from rail trails up to the blue trails at Keppoch
A size Large, It has a Deore drivetrain and I through on a wider bar. 720mm wide bars and a 50mm Easton Vice stem for more modern handling and feel. These bars are a lot wider and stem a lot shorter than what was usually stock on entry level trail bikes in 2010! Makes a very large difference. The bike also has Tektro mechanical brakes which should be enough for most beginner speeds. Not much special about it but its a fun bike for a newer rider!
Located just outside of Truro.
Bike is tight and shifts well. Chain has lots of life in it.
$500
