2011 Niner Rip 9 (Large)
Selling my 2011 Niner Rip 9. I built this bike up in 2014 and it’s been my main bike since then. The past few years I’ve been riding it slackened out with a 2 degree geoshift headset and a 150 mm fork (over forked by 10 mm). Sad to see this one go, but I have to make room for more bikes. The damper service was just done by Granite Suspension on the rear shock and the fork is essentially new (swapped over from new bike).
It’s been a great bike for riding the local Halifax trails (favourites being Time Flies/Time Out and Gord’s Gold in MacRun and Flip Side/Death March in Whopper). It’s also a blast for some laps at Wentworth.
The frame’s in good shape with typical dings and scratches. The lower linkage hangs below bottom bracket so it’s taken it’s fair share of scrapes but it’s just cosmetic and only something you see when the bike is upside down.
$1000
Frame: 2011 Niner Rip 9 Aluminium Raw (glows in the dark!) 117 mm rear travel
Shock: Fox Float RP23 (NOTE: The Lockout/ProPedal no longer works so it’s more like a Fox Float R now. I very rarely used the lockout anyway, the short rear travel and suspension design pedals really well)
Fork: 2024 Rock Shox Revelation RC 150 mm (Just a few rides on it, was a new take off from my Devinci Troy)
Wheels: WTB i29 32H (29 mm internal diameter)
Front Hub: Hope Pro 2 Evo 110 mm (with torque caps)
Rear Hub: Hope Pro 4 142 mm (DT Swiss Through Axle
Crankset: Shimano XT with a 1x 28T North Shore Billet Narrow Wide Chainring
Head Set: Wolf Tooth 2 Degree GeoShift
Stem: Straighline 50mm (31.8)
Bars: Niner Flat Bar
Drivetrain: Microshift Advent X 11-48 10 speed
Front Tire: Maxxis DHF 3C MaxxGrip Exo 29 x 2.5 (Setup tubeless with Stan’s)
Rear Tire: Specialized Purgatory Grid Trail 2Bliss Ready T9 29 x 2.4 (Setup tubeless with Stan’s)
Seat Post: Thomson Elite Dropper 125 mm travel
Dropper Remote: ZTTO lever (similar to older wolftooth remotes, works well enough).
Brakes: Shimano XT M785 (G-Type Ti Metallic/Titanium Disc Brake Pads)
Rotors: Magura 180 mm rear, 203 mm front (installed recently)
Saddle: WTB Volt
