2015 Specialized Tarmac 56cm
Fact 9R full carbon frame and fork, 130mm QR dropout, fork has black multicam hydrographics
SRAM Force 22 drivetrain, new Red 22 chain and low km’s on cassette, Kogel ceramic bearing derailleur pulleys
FSA SL-K Light 172.5mm crankset 50/34 chainrings
Kogel BB30 ceramic bearing bottom bracket
SRAM Force 22 brakes with new pads
Stan’s Alpha 340 Team wheelset with S-Works Turbo Pro 26c tires
Ritchey WCS 100mm stem and 42mm Ritchey Logicurve bar, Supacaz super sticky kush bar tape
Specialized Fact carbon seatpost and Romin Evo 155mm saddle
Shimano SPD-SL pedals
Weighs 15 pounds 6 ounces with the pedals off.
The frame has approximately 6400km of use, and approximately 2500km of use on the drivetrain and wheels. Tires, cables, and housing were replaced last spring. The bottom bracket and derailleur pulley wheels are both made by Kogel and have ceramic bearings. The chain, bar tape, and brake pads are new. The fork was replaced under warranty, but didn’t match the bike so I had multicam black hydrographics installed. The left side shift lever is scratched from sliding out, my left leg took most of the damage though. I’m a trained mechanic and the bike is in excellent working condition.
SOLD. Thanks for looking.
