Upgraded 2018 giant trance 4 spec is about equivalent to the top of the line model
Will fit riders from around 4,10-5,5 27.5” wheels
There is some cosmetic damage but it works perfectly aside from the dropper post
Spec:
•Fox 34 performance 160mm fork
•Full shimano xt drivetrain (xt cranks and derailleur is only 2 months old)
• 2020 sram code r brakes 200/180mm rotor
• raceface atlas bar cut down to 775mm cash money gold
• NS bikes lite stem 35mm diameter
• one up upgrade cassette 12-47 and one up narrow wide chainring 34t
• rockshox deluxe r shock (serviced at start of season
• giant dropper post needs service or replacement ( does not go up without you taping it)
• giant wheelset (has some dents but still seals tubeless no problem and the front could use new bearings
•maxxis minion dhf 2.3” and maxxis aggressor 2,3 dd rear tire
• matchmaker on the shifter and brake so there’s only one bar clamp on each side
• wolf tooth dropper post remote 4 months old
Located in hammonds plains
Pictures won’t work but text me (902)-478-0035 if your interested
