All parts have been grabbed up. cleaning up shop
Gone-Cleaning out the shop (basement).
All parts are in working order with typical wear and tear.
Taken-Bontrager bar and stem. Bar is 75mm wide.
Taken-Resin brake pads, two sets, shimano/TRP 4T Race. The basic bike co.
Taken-X Fusion Shock- 210mm x 55mm. Works fine, just upgraded. Might need a service.
Taken-X Fusion manic dropper, 170mm, 34.9 diameter. Has lever and cable clamp with it
Taken-PNW DROPPER. 150 mm. 31.6 diameter post
Taken-Fork- RockShox Recon Silver, Solo Air spring, Motion Control damper, lockout, tapered steerer, 42mm offset, Boost110, Maxle Stealth, 140mm travel
I’ll take the dropper, sent you a pm
Sent you a DM about the fork.
I would like the brake pads! I’ll send you a DM.
