DT Swiss EX511 on Project321 Hubs. Custom hand built 29er wheel set
Looking for a custom hand built wheel-set, specifically made with the demands of East Coast Enduro in mind?
For Sale Now. :fire: $1800
Project 321 G3 Hubs in Maple on DT Swiss EX511’s with Sapim spokes and DT Swiss squrox pro head brass nipples.
The perfect balance between compliance, durability and lightning fast hub engagement.
Full Specs on the EP001 Project.
29 inch EX511 Rims (Alu)
Project 321 G3 Hubs (32H Rear/28H Front)
Sapim Race Spoke
DT Swiss Sqorox pro head brass nipples.
DT Swiss 29mm Rim Tape
DT Swiss Valves
Project321 G3
Our approach with G3 was to build a hub that strikes the ideal balance between strength, weight, reliability, and efficiency. The result of this design philosophy is a robust and efficient hub set with instant, rock-solid engagement.
Engagement
G3 hubs use the same 72 tooth drive ring and three-step magnetically actuated pawls as our proven G2 hubs. To increase engagement without compromising reliability we added two additional pawls instead of miniaturizing the teeth on the drive ring and pawls. A total of eight pawls work in teams of two, to give 1.25° or 288 points of engagement. We believe this gives riders the ideal balance of instant engagement and rock-solid reliability.
G3 is full of improvements, Learn more about what’s new in our G3 Hubs.
6-Lock
6-Lock is a new patent pending technology by Project321. 6-Lock is an enhanced six bolt design that features stainless steel bolt threads. No lockring is required, only T25 Torx hardware, giving the rider true six bolt rotor retention. 6-Lock easily converts to center lock, giving you unrestrained brake rotor optionality. watch how.
G3 Front Hub are made with aerospace grade 7075-T6 aluminum, one of the toughest metals for hubs on the market. All hubs come in 1 of 12 vivid colours and are fully anodized to look as good as they perform.
What about revolution carbon? that’s what I ride out here in BC seems bulletproof. Or spoke X. My friend is 320 6’7’ and he has broken spoke x carbon yet.
We ride silver star and big white mainly.
Thanks for the insight.
After years of riding and testing/following market trends I am confident that Aluminium rims are the way to go for Enduro/DH.
Cheers.
Be a pretty sweet Easter Gift.
Top
I’ve been riding P321’s a little over a month, and I can now say I’m a believer in Neodymium magnets :magnet:. These hubs are top-tier y’all
Bump
