Link to Pinkbike ad with pics
2017 Pivot Mach 429 Trail.
Spec:
Fox 34 Factory Fit4 130mm. 2018 fork but damper was upgraded to the 2020 damper this fall. No rides on it since it was upgraded.
Fox Factory Float rear shock
Fox Factory Transfer Post 150mm. Serviced this fall by S4 in Quebec
XTR 11spd Shifter and derailleur
XT M8000 Brakes
CrankBrothers Cobalt handlebar, cut to 720mm
Pro Stem 50mm
New chain
Bontrager Montrose saddle
2 choices for the wheels. You can purchase with:
Bontrager Line Elite 30 wheels that come with Bontrager XR4 29x2.40 tires or
Custom built wheels with DT Swiss XR361 rims, XTR hubs and DT Swiss Super Comp spokes.
The second set is much lighter. Bike without pedals with the 2nd set of wheels is under 27lbs.
You can choose the cassette, either 11-42 or 11-46. Both are XT
