2021 Devinci Troy GX.
Size large. Aluminum frame. Bought new in 2021. Barely ridden in the past two years. Serviced annually at Sportwheels. Suspension was serviced by Granite Suspension in late 2022.
Fork: RockShox Pike Select+
Rear Shock: RockShox SuperDeluxe Select R Db. Trunnion | 2T |185x52.5
Brakes: SRAM G2 RS | 4 Pistons with SRAM Centerline | 200mm rotors
Drivetrain: SRAM GX Eagle
Front wheel: RaceFace AR35 Offset | 35mm inner | TR with Factor XD601SB/A | 6bolts | TA 15x110mm
Rear wheel: RaceFace AR35 Offset | 35mm inner | TR with Factor XDH62SB/A | 6bolts | TA 12x157mm | XD
Tires: Maxxis Minion
$2500. Message me if you’re interested.
Sold.
