The bike is a real mix of components with a long history. I got it as a hardtail and swapped the frame, then upgraded parts as necessary over the years. Very versatile and fun bike. It was set up for enduro/all-mountain for a while then set up more for downhill later on. The rear suspension has many adjustments (Head angle, travel, progressiveness, etc). Very good mechanical condition, good cosmetic condition. Reason for selling is that I rarely have time to ride it these days. PM me if you are interested or have any questions.
Bike is located in Dartmouth. Local pickup Only, Cash Only. No trades.
Price: $600
Frame: 2005 Specialized Big Hit FSR, Medium, 165-206mm adjustable travel
Fork: 2001 Marzocchi Bomber Junior T, 150mm Travel
Shock: Fox Vanilla RC, 450lb/in spring
Derailleur: Shimano SLX M662, 9sp, Shadow, Long Cage
Front Tire: Kenda K-Rad 26 x 2.3
Rear Tire: Kenda K-Rad 24 x 2.3
Front Rim: Alex Rims MX22
Rear Rim: Sun Rims Double Track SL1
Front Hub: Shimano HB-M475
Rear Hub: Shimano FH-M525
Shifter: SLX SL-M590, 9sp, two-way release
Brakes: Hayes Nine, 203mm rotors
Cranks: Kona Bulge, BMX style, splined
Pedals: Kona Jackshit
Handlebar: MEC Alloy, 780mm wide, 35mm clamp, 15mm rise
Stem: MEC Alloy, 35mm long, 35mm clamp
Chainring: Shimano 32T, 104mm BCD
Cassette: Shimano 11-34T, 9sp
Weight: Approx. 40lbs
