Selling a low use wage gx axs wireless deruillier, shifter, battery and charger.
Swapped out as I preferred mechanical shifting.
400 obo. Trades may be an option .
Located in Wolfville area.
Interesting to hear you prefer mechanical shifting. If it were an 11-speed, I might be tempted. ![]()
Niche use case issues. I found the AXS shifter had too light of action so I was prone to miss shifts by accidentally bumping it when riding in gnarly terrain.
The problem was especially bad in situations that involved a technical hike a bike. Scrambling up a cliff to access a rock chute or drop with minimal run in. If I didn’t double check my gearing at the start of every run, bad things would happen. When you only have 1-2 bike lengths to get up to speed before hitting a feature you need to be 100% positive your in gear. With the AXS stuff I had a bunch of close calls.
Not worth the risk. If there was a shifter mod that keeps the solid feel of the mechanical shifter, I would have kept it. As in normal use, it’s great. For free rideing, it was a major hazard.
just add a cassette and your set!
boop.
price drop, was 500 now 400.
sent you a message
If you don’t sell it the buttons inside can likely be swapped out for stiffer versions.
I used to develop industrial engine controls and button feel is pretty important, I have tested and swapped out lots of them. I forgot to feel the ones on that bike at send fest but from the shape/size of the shifter I am pretty sure I already know what’s in there.
