Park Tool TS-2 Professional Wheel Truing Stand SOLD
Park Tool TS-2 Professional Wheel Truing Stand.
The Park Tool Professional Truing Stand is the stand to choose for heavy shop use. Accepts wheels from 16" to 28" with or without tire removed. Both axle-holding uprights move simultaneously, always centering wheel hub with calipers, regardless of hub width. Calipers and caliper arm are spring-loaded to prevent jamming with badly out-of-true wheels. Made of heavy chrome plated steel with nylon bushings at pivot points. Can be bench-mounted or vise-held. The standard of the industry. If a forward or backward tilt is desired, use with Truing Stand Tilting Base (TSB-2) shown below. For precision work, the TS-2 should be used with the WAG-4 Professional Wheel Alignment Gauge. Opens up to accept hubs 150mm wide.
This stand is in excellent condition. I just rebuilt it with the TS-RK Rebuild Kit. The 238K Caliper Upgrade Kit is installed, as well as a new Upright Knob. The stand has the TSB-2 Truing Stand Tilting Base installed. The stand has been centered.
Also included areTS-2EXT.3 Truing Stand Extension Adapters, TS2-TA Thru Axle Adapters, a pair of new caliper springs, and 12mm and 15mm Unior Thru Axle Stand Adapters.
This stand will accept a 29" MTB wheel with a tire mounted when the Truing Stand Extension Adapters are installed.
SOLD
