Do any shops in Halifax carry the bleed funnel for Shimano? Also, mineral oil locally?
Thanks!
Thanks!
I use one of these for a funnel:
cut the bottom off and just cut the tip a bit smaller than the port and it will thread right in no prob. Available at any dollarstore. Use an old syringe to remove the oil before you remove it when done the bleed.
The Bike Pedaler sells oil.
Thanks @bent6543!
MEC carries the mineral oil and bleed kits. The bleed kits are a double syringe type instead of using the funnel. Syringes for mineral oil and DOT fluid are included.
I have the bleed kit with funnel for Shimano brakes, no fluid though. I wouldn’t be able to get it to you until next Sunday though. If you don’t sort it out before then you’re welcome to use it @JeffV
