Sold - 2019 Devinci Troy 29 GX Eagle Bike - Medium
Selling as I’m no longer riding. Has not been ridden in 2 years
Asking $1,800
Pedals upgraded to Deity Deftrap
SPECS:
Wheel Size 29"
Frame Material Aluminum
Frame Material Details Optimum G04 6066-T6 alloy frame, chainstays, and seatstays, rubber downtube and chainstay protectors
Rear Travel 140mm
Rear Shock RockShox Deluxe RL Debonair, 185mm x 52.5mm trunnion mount
Fork RockShox Pike Charger 2 RC DB, 15x110mm Boost axle, 51mm offset
Fork Travel 150mm
Head Tube Diameter Tapered, 1.125" top, 1.5" bottom|
Headset FSA Orbit 1.5 Zero Stack
Handlebar Race Face Aeffect R, 35mm clamp, 780mm width
Stem|V2 Pro, 35mm clamp, 50mm length|
Brakes SRAM Guide R, Centerline rotors, 200mm front, 180mm rear
Brake Levers SRAM Guide R
Shifters SRAM GX Eagle, 12-speed
Rear Derailleur SRAM GX Eagle, 12-speed
Cranks SRAM GX Eagle, Super Boost
Chainrings SRAM GX Eagle, 32 tooth
Bottom Bracket SRAM DUB 73mm threaded
Chain SRAM GX Eagle, 12-speed
Cassette SRAM XG1275, 12-speed, 10-50 tooth
Rims Race Face AR35, 35mm inner width
Hubs Front: Novatec D791SB-B15, 6-bolt rotor, 32 hole, 15x110mm Boost
Rear: Novatec XDH42SB/A-157, 6-bolt rotor, 32 hole, 12x157mm Super Boost with XD driver
Spokes Stainless 14g with Nylok
Tires Front: Maxxis Minion DHF, 3C, EXO, TR, 29" x 2.5" WT
Rear: Maxxis Minion DHR II, 3C, EXO, TR, 29" x 2.4" WT
Seatpost TranzX dropper, 1x remote
Rear Dropout / Hub Dimensions|12x157mm Super Boost
Retail Price$3,749
