https://www.pinkbike.com/buysell/3567398/
Good condition 2020 Yeti SB150 Turq T3 Build with DT Swiss XMC Carbon Wheels.
Fork and Shock have just been overhauled, not ridden since overhaul.
New Yeti Saddle
New Bottom Bracket
New Diety Ridgeline handlebar 800mm, not cut
New ODI Pro Grips
Drivetrain replaced in summer 2022.
Tires @90%
Additional pictures upon request.
Will ship within Canada at buyers expense.
Pedals not included.
Manufacturer Specs Below;
Product
Yeti SB150 T3 Bike
Model Year
2020
Wheel Size
29"
Frame Material
Carbon Fiber
Frame Material Details
TURQ Series carbon fiber frame; down tube and chainstay protection
Rear Travel
150mm
Rear Shock
FOX X2 Factory, 230mm x 60mm
Fork
FOX 36 Factory, GRIP2 damper, 44mm offset
Fork Travel
170mm
Head Tube Diameter
Tapered, 1.125" top, 1.5" bottom
Headset
Cane Creek 40 integrated
Handlebar
Diety Ridgeline, 35mm bore, 800mm width
Stem
Race Face Turbine, 35mm clamp, 50mm length
Grips
ODI Elite Pro
Brakes
SRAM Code RSC, SRAM CenterLine rotors (200mm front, 180mm rear)
Brake Levers
SRAM Code RSC
Drivetrain
1x
Shifters
SRAM XX1 Eagle, 12-speed
Rear Derailleur
Cranks
SRAM X01 Eagle, 12-speed, 170mm length
Chainrings
SRAM X01 Eagle, 30 tooth
Bottom Bracket
SRAM DUB BB92 PressFit
Pedals
N/A
Chain
Cassette
SRAM XX1 Eagle XG-1299, 12-speed, 10-50 tooth
Rims
DT Swiss XMC 1200 Carbon, 30mm internal width
Seatpost
FOX Transfer Factory
Drop: 125mm (SM), 150mm (MD), 175mm (LG/XL)
Seatpost Diameter
31.6mm
Seatpost Clamp
Single bolt, 36.4mm
Rear Dropout / Hub Dimensions
148x12mm Boost
Max. Tire Size
29" x 2.5"
Bottle Cage Mounts
Yes (single)
