SOLD!!!
2016 - (Note: capable of 29" wheel set)
FRAME -M5 alloy, Trail 650b Geometry, internal cable routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, front derailleur compatible w/ Taco Blade, 150mm travel
HEADSET - Hella Flush, 1-1/8"" and 1-1/2"" threadless, Campy style upper w/ 1-1/2"" lower, cartridge bearings
SEAT BINDER Specialized, 7050 alloy, single bolt, 34.9mm
REAR SHOCK - Custom FOX FLOAT Evolution CTD, AUTOSAG, Rx Trail Tune, 197x47.6mm
FORK - Performance Series 34 FLOAT 27.5 150 FIT4
WHEELS (Note: capable of 29" wheel set)
RIMS - Roval 650b, alloy
FRONT HUB - Specialized, Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 24h
REAR HUB Specialized, Hi Lo disc, 4x sealed cartridge bearings, 12mm thru-axle, 28h
SPOKES - DT Swiss Industry, stainless
FRONT TIRE - Specialized Butcher folding bead, 650bx2.8""
REAR TIRE - Specialized Butcher folding bead, 650bx2.8""
INNER TUBES Standard, Presta valve
REAR DERAILLEUR - Shimano SLX 11-speed
SHIFT LEVER Shimano 11-speed, Matchmaker clamp
CASSETTE SRAM 11-speed
CRANKSET Custom SRAM S-1250, 7050 alloy arms, 10-speed double, PF30, 36/22T, 104/64mm BCD spider
BOTTOM BRACKET SRAM, PF30, OS press-in bearings, sealed cartridge
STEM - Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS - Specialized, 6000 alloy, 8-degree backsweep, 6-degree upsweep, 25mm rise, 750mm, 31.8mm
SADDLE - Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST - Command Post IRcc, cruiser control technology, micro-adjust height adjustable, alien head design, bottom mount cable routing, remote adjust lever, 30.9mm, S: 100mm travel, M/L/XL: 125mm
FRONT BRAKE - Shimano Deore, hydraulic disc, resin pads
REAR BRAKE - Shimano Deore, hydraulic disc, resin pads
BRAKE LEVERS - Shimano BL-M447, I-spec compatible
