Rockshox Recon 351 Soloair- for 26” wheel. Disc brake only. 130mm travel (can easily be lowered to any travel between 80-120mm using spacers) with Motion Control damper- rebound and lockout. Quick release axle. Fork is in good shape with minor wear, stanchions are perfect- no scratches or damage of any kind.
Tough to find straight 1 1/8” steer tube that is 8 1/4” in length.
Just replaced the damper seals as well as the damper and bath oil. Fork is good to go for more years of use.
Great upgrade for a XC or trail bike fork with a coil or limited adjustments.
Do you have the spacers to lower the travel to 80mm by any chance? If not, what year is the fork? I will look up if those spacers can be bought online somewhere.
Hi, I don’t have the spacers. The fork is a 2007. I think the Rockshox All Travel Spacer kit would work fine- Rockshox part# 11.4015.450.000
I see that the above slide onto the air shaft, I believe the older version spacers for the Recon (11.4310.467.000) snapped onto the air shaft similar to the Fox of the same era.
Excerpt from the 2007 Rockshox Technical Manual showing the spacer configurations-
