Hi, i have a fully functioning XC or aggressive trail brake set that work great. I took them off my bike a few seasons ago. They’re from 2017, but have been bled and were designed for an internal cable routed brake. You can make these external but that may require some longer housing depending on your frame!
150$ for the set! Both are running shimano housing and have brake blocks for the calipers. Pads are in fine shape with plenty of surface. Rotors are 6 BOLT with sized 180mm front and 160 rear.
What’s the length of the rear brake cable?
Hi there, it’s 57 an 3/4 inches long!
Front is 30 and 3/4 inches.
