SON Dynamo Hub and Sinewave Light Package
Turn-Key ultra-endurance and bikepacking light and power setup: Sinewave Beacon 2 + Schmidt SON 28 Centerlock 12x100 hub.
Selling a premium, plug-and-play dynamo power and lighting system. This setup was lightly used for just one summer season and is in immaculate functional and cosmetic condition. This is a complete, integrated cockpit solution, perfect for anyone gearing up for a major bikepacking route, ultra-endurance event, or multi-day touring epic. It eliminates the need for bulky external battery packs by generating high-efficiency power right from your front hub.
What’s Included:
Sinewave Cycles Beacon 2 Headlight: The latest generation of the legendary 750-lumen powerhouse. Features an improved, highly efficient built-in USB charger to power your GPS, phone, or cache battery while riding. It offers an updated electronic design with a flicker-free beam even at ultra-low climbing speeds, and can be back-powered via an external power bank if you need full brightness while stopped.
Schmidt SON 28 12 Dynamo Hub: Specs:12mm x 100mm Thru-Axle, 28 Hole, Centerlock Disc. Black anodized finish. Standard spade terminal connections. Bearings are silky smooth with zero play, exactly as you’d expect from German engineering. Includes the original factory manual.
K-Edge Max Garmin Combo Mount: Robust, CNC-machined aluminum handlebar mount that keeps your Garmin secure and centered over the stem while leaving the handlebars completely clear.
Sinewave Aluminum GoPro Mount Adapter: Connects the Beacon 2 directly to the underside of the K-Edge mount for an incredibly clean, centered, and vibration-free cockpit setup.
Wiring & Spares: Comes with a Sinewave DC power cable plug and a fresh package of premium Pico insulated female spade connectors for a clean, custom-length installation on your rig.
Condition: Excellent, lightly used condition.
Asking $800
