Bottomed out a little hard on Mac Run this morning and the rim (undamaged) put a small slash on the sidewall just above the rim. Small enough that I thought the sealant might seal it up. It didn’t and I had to pop in a tube.
Anyone patch up a situation like this? It’s pretty close to the bead.
Yup, you can patch it internally. I use double automotive patches (small first, and then cover with a second larger patch). It will bulge at that spot though, and you may need a tube forever, but at least you won’t need to throw out the tire.
When I went tubeless I swore I would never use a tube again. I have a spare rear tire that will work, just thought it would be a shame to toss this with such a small slash.
So two patches. I’ll give that a go. Thanks.
That’s what I get for watching “Nothing’s For Free” while drinking coffee before a ride.
I guess it depends how large it is, but I’ve just used duct tape before and it worked fine
Do you think it will stand up
To another monstrous, super aggressive two foot drop?
I haven’t personally tried it yet, however I’ve heard of good results with this method
starts at about 1:39, actual repair starts at about 4:38.
basically clean/rough it up, sew it up, glue and patch inside, glue outside. will hopefully hold sealant.
As for hitting more drops, you have to ask yourself: What Would Brage Vestavik Do?
I’m sure he’s trying to figure out how to fix frames.
Thanks for the video. I’ll check it out.
I have had success with this, but not always. Really depends on size and where it is.
FYI-Park Tool make a really good patch kit, but recommend picking up gorilla glue instead of the stuff they provide.
CN
Sidewalls are tough but I’ve had success using roof repair tar and patches.
