WTB: Fox Spring 450 or 500
Looking here before buying new
Must be people with springs piling up maybe an ongoing spring swap thread would help people?
I needed a 500 coil for my rock shox. Cyclesmith was useless they didnt know what to order.
Theinsideline.ca had what i needed they carry a few brands
What length?
I have a couple of old coils; steel and ti in that range.
Did you give them the length, stroke, compression ratio, or weight (#)?
I thought fox only had two diameter options so I didn’t give details.
This would be 35mm ID and marked for 3" of stroke or more.
Thanks
Glad you were able to find it nonetheless.
There are 3 ID sizes for coils out there currently, some old old stuff might differ. But for the most part:
-35mm is Fox/ Marzocchi (current Marz stuff, older bomber shocks may differ)
-36mm is Ohlins, DVO/ Cane Creek, X-Fusion- these 36mm coils will work with the 35mm Fox/ Bomber shocks with no issues, there are adapters available but you can get away without them typically
-38mm is modern Rockshox- there are adapters available to reduce these coils to fit Fox and they work quite well, i’ve put Rockshox coils on a few Fox shocks now with no issues. The biggest issue is availability on the adapters.
Thanks for the info, I actually have a CNC so I could make an adapter if it was hard to find but it makes sense that 36mm would fit no problem.
I just realized you have a local suspension shop. If you need some spring adapters or anything else like bushings, special tools, branded merch let me know. I am not to far away from you.
Thanks. Will do!
