Let me know if you need some, I have extra…
And I can’t figure out why Rockhopper needs Lube on the trail.
That’s some kinky shit, man
Haha… wondered about that one myself!
I used to carry the dérailleur hanger, and even used one once in Wentworth after breaking one, but any good mountain biker should know how to make a single speed to get ya out of the woods. It’s something everybody should have to do at least once.
Sorry for wandering farther off topic, but in all seriousness, I wonder the best way to do the single speed to get you home. Assuming a hard tail so you can avoid considering rear suspension issues, people claim that a good chainline is necessary to avoid the chain wandering. Is it iconoclastic to suggest small-small for us luddites with more than one ring? Obviously then the chain can’t shift to a different cog or ring. Nearly a useless gear if you have a 1x but would be a reasonably useful in 2x or 3x.
Of course I also wonder whether tension might be as important as chainline.
I’m not sure if I’ve done it since owning a full suspension bike. I use the middle ring and a middle cog. It has to be tight. It never works great at all. I find the chain often tries to climb to the larger cog making it so tight the drivetrain does not turn. It’s an odd setup. I suppose using the large cog and with a large ring would give it the least change of trying to change gears on it’s own. Maybe I should start packing a hanger again. lol
I had to do it on the way to work last year after losing my derailleur to a rock that flipped between the spokes and derailleur. I removed the derailleur and shortened the chain and locked out the suspension but the little sag that still occurred caused the chain to tighten up further and you could feel the tension through the bottom bracket! Thankfully no damage to the press fit or frame and I still arrived at work on time.
what kind were they? have you tried the pedros levers? they’re great.
I feel so poorly prepared now. I hardly bring anything when I do my regular rides.
- CO2 inflator head (tiny) and tubeless tire plug kit in my side pocket.
- 25g cartridge taped to downtube
- Cellphone in other pocket
- 1L water or gatorade
@joshm it all depends where you ride I guess and how far you’re prepared to walk to get out.
I’d suggest that the amount of gear people carry is equivalent to the distance they are willing to walk out of the woods, i.e. more gear = less walking
Here’s what my pack looks like plus 2L of water in the reservoir. The stuff to the right of the pump is what I would bring on an extended or remote ride plus sometimes a Garmin mapping GPS unit. The pocket chainsaw only comes along if I know there’s something that needs to be cleared.
here it is all packed up
Thanks for packing a chain tool
no prob, more riding, less walking. Thanks for knowing how to use one!
I’ve used a chain tool far more than I would like to admit, very important thing to carry along. I also carry the spare pin that came with it.
I have carried a chain tool on many rides when I haven’t needed one, but never on the rides I have!
